8 years agoTSE and Simple Socket Server - lost packets
Hello Altera Forums,
After much struggle, I have managed to get the simple socket server running on my Arria V starter kit. I'm still having some problems:- I can connect to the DCHP sometimes, but not consistently.
- I can ping, but I get a high packet loss:
--- xxx.xxx.60.71 ping statistics ---
100 packets transmitted, 25 received, 75% packet loss, time 98999ms
rtt min/avg/max/mdev = 0.381/0.452/0.880/0.099 ms - I can telnet to the server, but it's very slow.
When you say it shows on the RX on signal tap, are you talking about the PHY side, or the avalon stream interface to the DMA?
I'm not sure (I'm still quite new to this)
For the RX, I'm listening to this node:
The mac address of the computer I'm sending the ping from shows up there. For RX, I'm listening tonios_system:inst2|nios_system_tse:tse|altera_eth_tse_mac:i_tse_mac|altera_tse_top_w_fifo_10_100_1000:U_MAC_TOP|altera_tse_gmii_io:U_GMIF|gm_rx_d_i_reg
The mac address shows up here too, but not every time I send a pingnios_system:inst2|nios_system_tse:tse|altera_eth_tse_mac:i_tse_mac|altera_tse_top_w_fifo_10_100_1000:U_MAC_TOP|altera_tse_gmii_io:U_GMIF|gm_tx_d_reg - Altera_Forum
I have fixed this issue. I had been using the schematic design method for writing the program. I switched to using verilog HDL without the block diagram file, and now I can ping the board with no packet loss as well as telnet in.
