16 years agoTristate Bridge between 32-bit and 16-bit data bus
Hello all! I am trying to write some data to an external 16-bit MRAM memory. This MRAM memory has a tristate data bus, so in my SOPC system, the CPU connects to an Avalon-MM Tristate Bridge, th...
16 years agoHello Jake,
Thanks for trying to help me. I did not write the MRAM controller, it just consists of an Avalon-MM interface with fixed wait states. Here are the settings for this interface: add_interface mram avalon_tristate end set_interface_property mram activeCSThroughReadLatency false set_interface_property mram bridgesToMaster "" set_interface_property mram holdTime 0 set_interface_property mram isMemoryDevice true set_interface_property mram isNonVolatileStorage false set_interface_property mram maximumPendingReadTransactions 0 set_interface_property mram printableDevice false set_interface_property mram readLatency 0 set_interface_property mram readWaitStates 3 set_interface_property mram readWaitTime 3 set_interface_property mram setupTime 1 set_interface_property mram timingUnits Cycles set_interface_property mram writeWaitStates 3 set_interface_property mram writeWaitTime 3 set_interface_property mram ENABLED true add_interface_port mram mram_oe_n read_n Input 1 add_interface_port mram mram_we_n write_n Input 1 add_interface_port mram mram_be_n byteenable_n Input 2 add_interface_port mram mram_address address Input 20 add_interface_port mram mram_data data Bidir 16 add_interface_port mram mram_cs_n chipselect_n Input 1 To answer your questions: yes I included byte enables, and the data width at the MRAM interface is 16 bits. I will check the signal waveforms at the tristate side to check if the 32-bit words are properly written to the tristate bridge. I will let you know if something comes out. Regards, Florian B.
