RHark
5 years agoTriple-Speed Ethernet with Max10 Issue
I'm implementing the triple speed ethernet IP (MAC, with a DP83867 as the PHY) and it's mostly working, but I've run into an issue on the TX side. When I transmit out a packet (any packet, type does...
- 5 years ago
I calculated and inserted the CRC myself, but I also tried letting the MAC do it automatically. Both times the final byte was corrupted.
I was able to get it working though, it appears as though the MAC IP was causing a much larger delay in the TXD to GTX_CLK path than I had thought. I inverted the GTX_CLK signal into the MAC and then was able to adjust the line delays on my PHY in order to get the signals to line up properly.
SengKok_L_Intel
5 years agoThis is glad to see the problem was resolved. Thank.
