Triple Speed Ethernet MDIO constraint
HI,
I find out more about MAG account support requirement. Apparently we still able to support MAG account customer as long as it doesn't involve design info exchange and limited to more FPGA general usage enquiry.
So, I guess it's fine to answer your TSE IP usage enquiry questions.
Intel TSE IP has clock divider setting called "host clock divisor" to lower down the MDIO bus operating frequency.
You can refer to below TSE user guide doc table 19 (page 27)
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf
Intel recommends that the division factor is defined such that the MDC frequency does not exceed 2.5 MHz. (< 3.33MHz or max 300ns spec requirement)
So, as long as you configure the MDC clk to be 2.5MHz then it's pretty safe and doesn't required additional timing constraint.
dlim
