8 years agoTriple Speed Ethernet - Send to PC?
Hello all.
I need help on further testing with the 'Using Triple Speed Ethernet on DE2-115 Boards' tutorial. (which is the one on the link below) ftp://ftp.altera.com/up/pub/altera_material/12.0/tutorials/de2-115/using_triple_speed_ethernet.pdf Right now, I am trying to send data to PC (a laptop) by connecting ethernet cable between Ethernet Port 1 of DE2-115 Board and PC's LAN port. I've done everything as the same as the tutorial, and from what I understand, data will be sent from Ethernet1 port of the board to PC, where I will use Wireshark to see the incoming packets. However, I don't see anything coming in to PC (looking at Wireshark) when I send packets. Except the periodic standard queries and initialization. I input strings in Altera Monitor Program, press enter to send, but nothing coming in. So the question here is... if I follow the 'Using Triple Speed Ethernet on DE2-115 Boards' tutorial, connect Ethernet1 port of DE2-115 board with PC's LAN port, send data (using Altera Monitor Program) through LAN Cable, packets should be received normally on PC, right? Or are there TSE register configurations I must do to make packets be acknowledged by PC? Has anyone done similar project? What do I need to do? Thanks in advance. EDIT : Fixed. It was a problem with my PC hardware, not the TSE settings problem.No RepliesBe the first to reply
