10 years agoTri speed Ethernet Interface Testbench for MAX 10 Device
Dear All, In Ethernet option of Interfce protocol in Quartus prime lite edition software there is a testbench for Ethernet protocl. If i want to send some data from FPGA to PC via Ethernet then should i write a verilog code or i can use this default testbench for Ethernet protocol. Sorry if you find this question dumb. But i am quite freaking out about the verilog code of Ethernet interface. Thanks in advance
1 Reply
If you want to run simulation, you can use the default testbench.
You can also consider refer to example below: MAX 10 Single-Port Triple Speed Ethernet and On-Board PHY Chip Design Example https://cloud.altera.com/devstore/platform/15.1.0/max-10-single-port-triple-speed-ethernet-and-on-board-phy-chip-design-example/ (This message was posted on behalf of Intel Corporation)
