10 years agoTransmitting frames with Triple-Speed Ethernet MegaCore over Ethernet/RGMII
Hello, I'm working with Quartus II, and had implemented the Triple-Speed Ethernet Megacore. I simulate my design with ModelSim Altera Starter Edition. My hardware is the BeMicro CV A9 with ...
10 years agoYou must ensure that both the TSE and the PHY are in 100 MBit/s mode. There is a register to set in the TSE (and/or an external signal, depending on your project) to force the 100 MBit/s mode, and also some MDIO registers to set in the PHY chip to prevent Gigabit/s autonegotiation. Check the datasheet. I'm not familiar with that PHY or that board, but in addition you may have to switch to an MII interface instead of RGMII.
