13 years agoTrace System Megacore Function Synthesis Error
I am trying to tap a working video design that captures live video from a CCD camera and displays it on the lcd. As, Quartus v12 provides IPs for tapping avalon-ST data i.e. avalon-ST video monitor a...
13 years agoIs it possible to upgrade your project to QSYS? I suspect that if you do that will fix the problem.
If not then please check that the two copies of the pipeline_base.v file are the same. If they are then deleting one of them should make the design compile. I really do recommend upgrading to QSYS unless you have good reasons why not though, as it's possible that you'll hit problems later on with SOPCB.
