17 years agoTone Generation
Hi I am facing problem regarding Generation of tones (like Busy, Beap, Dial tone), if any help regarding this.
17 years agoHi OrchestraDirector
Certainly an Orchestra Director is the best guy to synthesize all sorts of tones. You are right, and the second method of using one clock is more practical. You can then generate frequencies with fine steps at any rate below .5Fclk using a modulo adder to address the LUT.Normally designers use a wide adder but then use few of its MSBs as LUT address. See AnalogDevices tutorial(DDS) Kaz
