11 years agoto use altlvds,how I can use LVDS bit clock and LVDS frame clock of ADC at the same t
In my board, there are 5AGXFB3H4F40C5N and TI ADS5294. The ADS5294 is a 80-MSPS 8-Channel ADC,The digital data from each channel ADC is output over two wires of LVDS output lines depending on the ...
11 years ago --- Quote Start --- You must work with frame clock or bit clock of A/D converter. FPGA's clock and ADC's clock are asynchronous you will have wrong data reception. Regards, Andrei --- Quote End --- Thanks again, Andrei. I'll use bit clock as the the input clock of ALTLVDS_RX's internal PLL, and use frame clock to decide whether to pulse rx_channel_data_align or not. Regards, zhangfeng
