SERMASWATHIKA
Contributor
2 years agotiming violation on ddr3 setup
Hi Team, I am using ddr3 IP controller in my design which operates at 200Mhz (avalon clock) and configured memory clock as 400 Mhz. With that settings when I compile the design, I am getting ne...
Fletch
2 years agoI was getting timing violations with my emif design until I found this: https://www.intel.com/content/www/us/en/support/programmable/articles/000078771.html.
In my case, I moved the qsys qip file before the sdc files in the qsf. I also had to modifiy the qsys qip file to move the ddr3_emif sdc file before the other sdc files in the qip.
Hope that helps.
SERMASWATHIKA
Contributor
2 years agoThanks for your response.
But i am compiling the design with the files order setup only.(first qip file then sdc file)
Still ddr has timing violation particularly for ddr3 memory clk as 400 and controller rate is 200.
