SERMASWATHIKA
Contributor
2 years agotiming violation on ddr3 setup
Hi Team, I am using ddr3 IP controller in my design which operates at 200Mhz (avalon clock) and configured memory clock as 400 Mhz. With that settings when I compile the design, I am getting ne...
AdzimZM_Altera
2 years agoHi
Please revert back the change. It's introducing more timing violation.
To help in fix the timing issue, please change the compiler setting in advanced setting (synthesis) for optimization technique to speed.
Please supply the afi_clk from ddr3 module to cpu and vic_0 module.
Adzim
SERMASWATHIKA
Contributor
2 years agoHi,
I have modified as you have suggested(optimization- speed) ,afi_clk to cpu,vic.
With that also timing violations are reported for ddr set up.
PLease check the attached project archive for reports
