SERMASWATHIKA
Contributor
2 years agotiming violation on ddr3 setup
Hi Team, I am using ddr3 IP controller in my design which operates at 200Mhz (avalon clock) and configured memory clock as 400 Mhz. With that settings when I compile the design, I am getting ne...
AdzimZM_Altera
2 years agoHi
"Are u suggesting to connect the pll_ref_clk directly with inclk from top ?"
- Yes, is that possible?
What is the other component that used that clock connection?
Adzim
- SERMASWATHIKA2 years ago
Contributor
hi ,
Ok i will check and let you know.
only ddr3, ethernet ip, pll is using that clock source only. that also connected through qsys clock source.
Contributor
Hi AdzimZM_Intel,
With that clock implementation also, timing violation is increased.
attached the archived project which contains the ddr_clk connected to top.
With that also tming violation is there..Please check
