17 years agoTiming Violation for legacy DDR2 Controller
Hi There, I generated DDR2 SDRAM controller using mega wizard for memory frequency of 125 MHz and data width of 8. Timing analysis is failing because of violation in read data synchronization p...
17 years agoHi,
in the wizard there is a section called "constraint"! Do you edit this section? In your installation directory "C:\Altera.." is there an example where the ddr2 sdram controller is used? You can copy the setting from the example! I fixed my problem in this way! Bye
