9 years agotiming questions -false path for the experts
Hi, I have a design that has value in it that define the code behavior, let call them: config_reg table_of_vaule 1. because of the nature of those things, they are deep in the design. ...
9 years ago --- Quote Start --- is not define as a "constant" in vhdl, however.... it will not change... --- Quote End --- so it is set early well before design starts using it even if (a) samples it from start the design is idle. That is ok
