9 years agotiming questions -false path for the experts
Hi, I have a design that has value in it that define the code behavior, let call them: config_reg table_of_vaule 1. because of the nature of those things, they are deep in the design. ...
9 years ago --- Quote Start --- The other option is to use en1 on reg(a) and en2 on next register and control delay of sampling between en1 & en2 --- Quote End --- just to correct myself. if conf_reg is constant then there is no problem. you can set false path from it an ignore my other notes
