anonimcs
Contributor
2 years agoTiming constraints of Intel IPs
Hi all, I have a design on Quartus 21.3 Pro and I noticed that the External Memory Interface IP for DDR4 memory has some timing violations within the IP core. I would expect that these kind of IP co...
RichardT_altera
2 years agoI think I have found what could be causing the problem.
It might be due to the location assignments in your design, causing it to be over-constrained with placement that's hard to meet timing.
Once I disabled all the location assignments in the assignment editor, the setup timing violation was resolved.
Could you please check and confirm this from your side ?
Richard Tan
anonimcs
Contributor
2 years agoBy location assignments did you mean the pin assignments ? I cannot change that as that would require a complete new PCB design..
