XXiao2
6 years agothere is a missing tcl file for the LL10G example design hardware test script file.
when I tried to run the tcl proc from list.tcl in system console terminal, it shows I am missing parameter_inc.tcl and I can not find it in the test directory.
- SengKok_L_Intel
Yes, the parameter_inc.tcl file is not available as i can see from my site as well. This is not required to run the ethernet test.
The TCL that you suppose to run is main.tcl.
Regards -SK
- XXiao2
I looked at the other tcl file and they are very helpful. For example, the list.tcl will list all the registers which might not be explained in the app note. Is it possible to get this file?
- SengKok_L_Intel
I understand you concern, the example design package come with all available scripts that sufficient to run the Ethernet test . I afraid that other script may not be available.
Regards -SK
