15 years agoThe sgdma in sopc has 8 bits per symbol?
Hi,I developed a component with a streaming soure interface whose data width is 32 bits(per symbol),but when I add this componet to a sopc system which also instantiatized a sgdma component,and the s...
8 years ago --- Quote Start --- Thanks for your reply,I set the symbol width of the component I developed as 8,and now it works ok! --- Quote End --- Hello, You mentioned that you developed a component and set symbol width to 8 and you have it working. I have exactly same error and I tried different ways by changing symbol bits of two-sides components, but all fail. Please, I need to explain for me what component you build to fix the problem and I would appreciate that so much ..
