csy
5 years agothe compatibility issue about the PCIe IP for Cyclone V and Cyclone IV
HI,
I am using EP4CGX50CF23I7N to design a new board with ARM + FPGA structure. And i need a pcie port on it.
As shown, EP4CGX50CF23I7N should be classified into Cyclone IV GX Series.
From Plat...
SengKok_L_Intel
5 years agoHi
- The IP is targeted for different devices, and you need to double-check if the data rate and link width that you plan to do is supported in both devices.
- If both devices use the AVMM interface, it should be straightforward for you to port over your application design from CV to CIV.
- Yes, as per the PCIe spec, both are similar.
Regards -SK
