18 years agotDSS violation in DDR2 HP controller function simulation
Hi everyone: I have an Arria GX Dev board. The DDR2 module on it is MICRON 32-MByte x 16 DDR2 SDRAM operating at 233MHz.But I can't access DDR2 SDRAM with DDR2 High-Performance controller 7.2 ...
17 years agoDid you properly configure the Micron DDR2 simulation model? The model is used for every speed grade part so you have to configure the settings file to match your DDR2 controller.
Jake
