14 years agotcp/ip stack
hi, I wanted to know where does the tcp/ip stack present in the linux machine which is using ubuntu 11.04, is it possible to integrate this kernel code tcp/ip stack with the...
14 years ago --- Quote Start --- hi, I wanted to know where does the tcp/ip stack present in the linux machine which is using ubuntu 11.04, is it possible to integrate this kernel code tcp/ip stack with the user code at the data link layer level?? Thanks --- Quote End --- What has this to do with Altera FPGAs / IP? Nial.
