RPett4
7 years agoStratix 10 SERDES Reference clock Error(20445)
I am trying to utilize a LVDS SERDES IP block on the Stratix 10 SoC Development Kit. Per the development kit schematic, I have "HDMIREFCLK_P" driving my "inclock" port of the SERDES IP Block. When I ...
SreekumarR_G_Intel
7 years agoCan you look at the bank connected to the clk input (which is PLL instantiated) and L:VDS bank which you plan to use both are same ?
Other easy way is , if you remove the pin assignment from the assignment editor and build the same. Then you can see inclk of the PLL where it is default mapping by the quartus. I believe you will get idea from the bank where it is mapping.
Thank you,
Sree
