Stratix 10 reset_status asserted after FPGA is totally configured ?
- 5 years ago
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
At the initial power-up, you may use the nint_done signal together to hold the core logic in reset before entering the user mode. The reset_status will be helpful when you reboot the host or issue a perst from the host or trigger the npor, while the FPGA image is still alive, and that signal can use to reset your application logic.
Thanks for the additional informations.
I think I haven't provided the whole picture, so I am trying once again:
Due to the nature of the S10 architecture the safest approach is to reset the user logic with the reset release ip output after the FPGA is completely configured.
Problem is, that we can't route the nint_done output of the reset release IP to the Avalon streaming masters / slaves that communicate with the S10 PCIe HardIP .
According to the UG on page 80 of the HIP with streaming interfaces, there is the statement that reset_status can be used to reset the user logic. This seems to solve the problem for us, since those avalon streaming slaves/masters can now be reset with reset_status und the other parts of the FPGA with the reset release IP output.
Is this a safe approach ?
