Stratix 10 PCIe ST IP configuration errors
- 5 years ago
The machine was causing the issue. Fixed by using a different machines PCIe port.
Thank you.
I’m glad that the issue is resolved, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
Is there anyway to circumvent Stratix 10 PCIe REFCLK requirements for configuration? The requirement is making the device not programmable on a server PCIe port. That particular machine works fine for Arria 10 PCIe designs. The PCIe slot is fully functional. The server is the only one with available virtualization support for the particular design. It would be great if there is some way to provide a separate reference clock. The issue is very frustrating as there should be no problem using the board on an extremely expensive server that has completely functional PCIe 3.0 compliant ports.
