HBhat2
Contributor
7 years agoStratix 10 L tile Native PHY unable to receive incremental data sent from TX and tested using FMC loopback card
Hi, I am using Stratix 10 SoC dev kit and testing the transceiver with FMC loopback card. I tested with the Board test System and all are looking fine with BER = 0. Even I opened the FMCA project ...
- 7 years agoHie, Its good news that you can receive the signal correctly. Yes, since you are using PCS direct, there is no word aligner hardware available. Hence, you will need to implement word aligner in the fabric. As for meeting timing in Stratix 10, we have a document to guide you. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/s10_hp_hb.pdf Please refer to section 2.3 and 2.4 mainly. Please let me know if you need any other information. Regards, Nathan
Nathan_R_Intel
Contributor
7 years agoHie,
I checked the design achieve, I could not find any connection issues. But do let me test in hardware. Will update you in a day or two.
Nathan
HBhat2
Contributor
7 years ago
