HBhat2
Contributor
7 years agoStratix 10 L-Tile FPGA- Native PHY - PCS to PMA interface
Hi, I planned to use PCS Direct between my custom PCS to PMA interface. Custom PCS works with TX_clkout frequency. So, there some cases where I may need to pause data for 1 cycle from Custom PCS to ...
- 7 years ago
Hie,
There is no PMA logic to check the status to read out the data from fifo when using PCS direct. You will need to implement the phase compensation fifo on your customer PCS.
The no data is present for 1 clock cycle, the serializer will populate itself with all 0s or 1s for the 1 clock cycle. Its equivalent to releasing the PMA out of reset without sending data.
Nathan
Nathan_R_Intel
Contributor
7 years agoHie,
Its good my explanation was clear enough to understand the serializer behavior.
Nathan
