Stratix 10 H-Tile Avalon Streaming PCIe IP Core - Root Port Configuration Space access
Arria 10, Cyclone 10 have some different compare with Stratix 10.
I dont think you can direct relate between both of them.
Detail, you better refer back to
Wincent_Intel
Thank you once again for your response!
The reason I refer to the Arria10, Cyclone 10 User Guide, is because I cannot find any Information regarding TLP-Routing in the Stratix 10 User Guide.
However, I think that information is also necessary on the Stratix 10 to properly use the PCIe IP-Core. My experience from Simulation suggests, that the Stratix 10 Root-Port IP-Core does indeed forward all Memory-Request to the PCIe-Link, ignoring Memory Base and Limit Registers in the Root-Ports Configuration Space Header.
It would be reassuring to know, whether that's the intended way to use the IP-Core.
