MUrba10
6 years agoStratix 10 E-TILE reference clock
Hello, I would like to use E-TILE transceiver reference clock input for clocking core logic bypassing transceiver. In "Intel® Stratix® 10 Device Family Pin Connection Guidelines" document in Table ...
Deshi_Intel
6 years agoHi Mikhail,
I have clarified with Intel internal team.
Unfortunately E-tile refclk doesn't support direct connection to FPGA core logic as I suspected earlier.
- This is a explanation mistake in S10 pin connection guide doc. We will fix and update the doc accordingly
My recommendation is as below
- If you insist of using E-tile refclk then you can choose to configure E-tile NativePHY in PLL mode where it convert one of E-tile transceiver channel into PLL that can be used to clock FPGA core logic. Refer to chapter 2.2.11 PLL mode
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_etile_xcvr_phy.pdf#page=63&zoom=100,0,0
- Else you can also use any IOPLL refclk pin or any IOPLL output clock to clock FPGA core logic
dlim
