Stratix 10 communicating with Arria V
I need to design a high speed communication interface (around 40 Gb/s across 8 differential lanes) between a Stratix 10 and Arria 5 FPGAs. To limit the design effort, I wanted to use Serial Lite.
However, it seems like the Stratix 10 supports SL3 while the Arria V supports SL2.
Please suggest an alternative that would limit the design effort to a minimum.
Hi shaiko,
You may use SL3 because I found that Stratix 10 and Arria V support SL3. For further information, you may refer link below, Table 1, https://www.intel.com/content/www/us/en/docs/programmable/683330/23-3-20-0-2/quick-reference.html
zying
- ZiYing_Intel
May I know you are using which quartus version?
zying
- host
I don't have a design yet.
I can use any Quartus version. - ZiYing_Intel
Hi shaiko,
My suggestion is you can use SL3 if you use the device Arria 10 instead of Arria V. For further information, you may refer link below, Table 1, https://www.intel.com/content/www/us/en/docs/programmable/683330/23-3-20-0-2/quick-reference.html
Besides that, as I know, only Arria 10 device has the special request for a special license to enable the Intel Quartus® Prime software to generate the FPGA configuration file (.sof) when using SL2. For further information, you may refer link below, Table 1 SerialLite II IP Core Release Information, https://www.intel.com/content/www/us/en/docs/programmable/683179/16-1-16-1/seriallite-ii-ip-core-overview.html
zying
- host
I need to design a high speed communication interface (around 40 Gb/s across 8 differential lanes) between a Stratix 10 and Arria 5.
That's a hard requirement - I can't use Arria 10. It must be Arria 5 and Stratix 10.
What's the easiest way to connect them ?
- ZiYing_Intel
Hi shaiko,
zying
- ZiYing_Intel
Hi shaiko,
Since your issue has been resolved, I am now close the case. If you happen any issue after the case closed, please do feel free to submit another issue.
zying
