Stratix 10 - Example design for dynamic reconfiguration
As I understand it, you have some inquiries on S10 L Tile dynamic reconfiguration example design. For your information, as I search through the internal database, it seems like there is no specific design on this. However, you can try to refer to the C10GX dynamic reconfiguration at the following link as reference:
Note that this design is using ATX PLL switching and channel reconfiguration. You need two ATX PLLs but does not need to perform ATX PLL reconfiguration.
Chee Pin
I downloaded the above example design and opened in the quartus. The top file is a .bdf file where I am seeing the reconfiguration ports are not connected to any controller. In this project, who will control the reconfiguration ports?
With Regards,
HPB
