9 years ago
Startix10GX device PIPE Native phy IP showing error channel misplacement error
I'm using Stratix10GX fpga devkit and generated PIPE Native phy IP throwing placement error as follows on Quartus17.1IR2.
any body have any ideas on how to fix this placement issue?
This may relates to quartus rule check I guess, since I see almost similar error on every experiment.
Satish
------------------------------Error(19376): PIPE master channel < txp[2](n) > has to be placed at second or fifth location of the HSSI tile. Error(14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 HSSI_PMA_TX_CGB(s)). Fix the errors described in the submessages, and then rerun the Fitter. The Intel FPGA Knowledge Database may also contain articles with information on how to resolve this periphery placement failure. Review the errors and then visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error(175001): The Fitter cannot place 1 HSSI_PMA_TX_CGB, which is within Stratix 10 L-Tile ES1 Transceiver Native PHY s10_phy_pipex4_altera_xcvr_native_s10_16930_ws3np3i.
Info(14596): Information about the failing component(s):
Info(175028): The HSSI_PMA_TX_CGB name(s): altera_phy|xcvr_native_s10_0|g_xcvr_native_insts[2].ct1_xcvr_native_inst|ct1_xcvr_native_inst|inst_ct1_xcvr_channel|gen_ct1_hssi_pma_tx_cgb.inst_ct1_hssi_pma_tx_cgb
Error(16234): No legal location could be found out of 95 considered location(s). Reasons why each location could not be used are summarized below:
Error(175006): Could not find path between the HSSI_PMA_TX_CGB and destination HSSI_CR_PMA_TX_BUF
Info(175027): Destination: HSSI_CR_PMA_TX_BUF altera_phy|xcvr_native_s10_0|g_xcvr_native_insts[2].ct1_xcvr_native_inst|ct1_xcvr_native_inst|inst_ct1_xcvr_channel|gen_ct1_hssi_cr_pma_tx_buf.inst_ct1_hssi_cr_pma_tx_buf
Error(175022): The HSSI_PMA_TX_CGB could not be placed in any location to satisfy its connectivity requirements
Info(175021): The HSSI_CR_PMA_TX_BUF was placed in location HSSICRPMATXBUF_1C2
Info(175029): 93 locations affected
Info(175029): HSSIPMATXCGB_1C3
Info(175029): HSSIPMATXCGB_1C4
Info(175029): HSSIPMATXCGB_1C5
Info(175029): HSSIPMATXCGB_1D0
Info(175029): HSSIPMATXCGB_1D1
Info(175029): HSSIPMATXCGB_1D2
Info(175029): HSSIPMATXCGB_1D3
Info(175029): HSSIPMATXCGB_1D4
Info(175029): HSSIPMATXCGB_1D5
Info(175029): HSSIPMATXCGB_1E0
Info(175029): HSSIPMATXCGB_1E1
Info(175029): HSSIPMATXCGB_1E2
Info(175029): and 81 more locations not displayed
Error(175003): The HSSI_PMA_TX_CGB location is occupied (2 locations affected)
Info(175029): HSSIPMATXCGB_1C0. Already placed at this location: HSSI_PMA_TX_CGB altera_phy|xcvr_native_s10_0|g_xcvr_native_insts[0].ct1_xcvr_native_inst|ct1_xcvr_native_inst|inst_ct1_xcvr_channel|gen_ct1_hssi_pma_tx_cgb.inst_ct1_hssi_pma_tx_cgb
Info(175029): HSSIPMATXCGB_1C1. Already placed at this location: HSSI_PMA_TX_CGB altera_phy|xcvr_native_s10_0|g_xcvr_native_insts[1].ct1_xcvr_native_inst|ct1_xcvr_native_inst|inst_ct1_xcvr_channel|gen_ct1_hssi_pma_tx_cgb.inst_ct1_hssi_pma_tx_cgb
Error(15307): Cannot apply project assignments to the design due to illegal or conflicting assignments. Refer to the other messages for corrective action.
Error(16297): An error has occurred while trying to initialize the plan stage.
Error: Quartus Prime Beta Fitter was unsuccessful. 10 errors, 1 warning
Error: Peak virtual memory: 11208 megabytes
Error: Processing ended: Tue Jul 18 11:58:08 2017
Error: Elapsed time: 00:03:44
Error: Total CPU time (on all processors): 00:01:49
Error(293001): Quartus Prime Beta Full Compilation was unsuccessful. 11 errors, 1 warning
