14 years agoStandalone USB to USB file transfer device
Hi.we are working on Standalone USB to USB file transfer device. what we plan is to make a usb controller in DE0-nano dev kit as well as the microcontroller inside it. Do we need to purchase IP Cores...
14 years ago --- Quote Start --- we are working on Standalone USB to USB file transfer device --- Quote End --- Why? What is the point? There would be no market for it. I can take a piece of wire (ethernet cable) and make an ethernet-to-ethernet file transfer device much easier :) But seriously, what are you really trying to do? --- Quote Start --- plan is to make a usb controller in DE0-nano dev kit as well as the microcontroller inside it. Do we need to purchase IP Cores regarding the USB Controller? or can we design it by ourselves? --- Quote End --- You don't even start there. You buy a microcontroller with two USB interfaces on it. Both of them need to be device interfaces if you expect to be able to have two PCs (hosts) view the micro as a USB device. --- Quote Start --- any pointers to read about? and about the microcontroller inside the fpga, is the nios II processor already included in the Quartus II? Thank you. --- Quote End --- You are going about it completely wrong. The new ARM Cortex microcontrollers come with a library called CMSIS that creates a uniform layer for USB interfaces on Cortex microcontrollers from all vendors. If you really want to create something that is file-system to file-system, then you have a need for software, not FPGA logic. Perhaps you could explain the application a little more clearly? That way we can see if there really is a need for an FPGA. Cheers, Dave
