SPI-to-Avalon-Bridge answers always IDLE
You may checkout the section 4. Avalon-ST Serial Peripheral Interface Core.
The Avalon-ST SPI core waits for the nSS signal to be asserted low, signifying that the SPI master is initiating a transaction. The core then starts shifting in bits from the input signal mosi.
Thus, the nss need to be low during the complete transaction.
- Jo9105 years ago
I already found section 4 and figure 6 in the documents, but figure 6 only shows a transaction including 1 byte. I don't know exactly how to write a complete transaction. What byte and what bit has to be sent first? I want to simulate a read operation at avalon adress 0x0000 0000 (that should be status register of the On-Chip-Flash) with Modelsim. After reading the documents, I think I have to sent the following bytes:
0x7A, 0x7C, 0x00, 0x10, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x7B, 0x00
But the IP Core always answers with IDLE (that means that there is no data to send).
Could you help me modifying my modelsim script attached in order to run my read operation?
Thank you.
- RichardT_altera5 years ago
Hi @Jo910
Sorry for the late reply. Do you need further help regards to this case?
I do not think I can get any useful information from the attachment.
You may checkout the design example here for reference.
Richard Tan
