13 years agoSPI Core: Strange problem with sample and shift clocks
Hi, All, I've an SPI Slave IP in my design, and I'm sending and receiving a single byte. Every 5-6 time, the bytes sent and received are wrong. I've looked inside the SPI core with SignalT...
13 years agoHi, FvM, thanks for the reply :-)
I'm using the serial peripheral interface - master / slave (http://www.cast-inc.com/ip-cores/interfaces/spi_ms/cast_spi_ms-a.pdf) IP core that comes with Qsys. I have one board with a Master instance of that core, communicating with another board with a Slave Instance. I'll try checking the clock constraints, but I'm not very hopeful: I have a NiosII with a TSE core in the same system, and they are working fine. Why should the SPI (which is rather slow) cause timing issues? I also tried inserting a 1 us delay between the SS_N and SCLK in the SPI master, but that didn't work either. Thanks, Ran
