14 years agoSpeed of SPI core problem
Hi I have generated a uClinux kernel for my DE0 board,and I use the IP core of SD card is SPI core with 30MHz clock (According to http://www.alterawiki.com/wiki/mmcsd). I can opera...
14 years agoYour SPI clock is 25000Hz aka 25kHz, so You get 25Kbps serialized speed or 25/8 = 3.125 KBps, so do the math:
to upload 1.7MB (1700KB) file, You need 1700 / 3.125 = 544 seconds or more than 9 minutes. Increase the SPI clock at least 100 times, so it should be 2500000Hz or 2.5MHz and do the tests again.
