14 years agoSpeed of SPI core problem
Hi I have generated a uClinux kernel for my DE0 board,and I use the IP core of SD card is SPI core with 30MHz clock (According to http://www.alterawiki.com/wiki/mmcsd). I can opera...
14 years ago --- Quote Start --- Increase the speed in spi core parameters. --- Quote End --- Thank you very much for your reply. I don't understand that how to change the speed parameter. I can't find such that speed parameter. Could you tell me more detail ??? Thank you in advance. The attached file is the SPI core parameter setting in SOPC. http://moon.cse.yzu.edu.tw/~s941643/file/SPIcore.png
