WKapp
7 years agoSpecifying timing relative to EMIF pll reference clock
Hello all, I am using an Arria 10 10AX027H4F35E3SG and have included a DDR4 EMIF. I am feeding the FPGA a 133MHz clock as the pll reference. This same clock is used for all the board interface tim...
WKapp
7 years agoNAli1,
Thank you for the reply. I had pretty much figured out there was no solution for this situation. I am surprised the designers of the IP did not consider this situation and accommodate it. Oh well, can’t change it now☹.
Unfortunately, I cannot use afi_clk externally as this FPGA is not the source of the board clock. There are many other FPGAs and external logic that all must be clocked in phase.
Bill
NurAida_A_Intel
7 years agoDear WKapp,
Understand the pain that you are facing. I sincerely apologize for the inconvenience caused.
NAli1
