Specifying timing relative to EMIF pll reference clock
Dear WKapp,
I really thank you for your detail explanation and now I think I understand your issue better. đ
You are trying to constraint timing for other logic (IN1 and OUT1) and not the EMIF as the EMIF donât need the additional timing constraint as per I explained before.
And from the diagram you attached, I can see that you are using the afi_clk to drive non-EMIF logic. As far as I know, there are no afi_clk exported from EMIF IP unless you are using âHard PHY onlyâ mode. Are you using âHard PHY onlyâ mode?
This afi_clk is actually meant for the custom controller to use and not for other logic like External FF.
Anyway, here is some constraint guideline that I hope is helpful for you to get some idea on how to constraint timing --> https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_timequest_cookbook.pdf
I believed the problem you are facing now is more to timing issue and not EMIF. My suggestion to you is to open new thread if you encounter any issue from the documentation and Timing expert will help you.
NAli1
