9 years agoSome trouble with HDMI RX ip core (Bitec IP core)
hi,guys I have some trouble when I used HDMI 2.0 IP CORE on my own Arroa 10 board. Nvidia GTX1060 is used HDMI 2.0 test signal source, connect to FPGA serdes pin through my own connect board. ...
8 years ago --- Quote Start --- Hi there, I am trying to use the ATX Plls on the HDMI reference design. I have re-compiled the software to use the ATX configuration, however the TX PLLs are not getting locked.Any suggestions/information on this front? --- Quote End --- In case this may be useful to someone. I can post more details on request: [list] [*]It is not advisable to use ATX Plls for lower HDMI rates, this due to jitter performance restrictions of the ATX. [*]The NIOS sw that comes with the reference design has got two cases, for fPLL and ATX-PLLs, however the case for the ATX has a bug: The re-calibration process does not distinguish fPLL/ATX cases, however the re-calibration process for each is slightly different.Hope it helps [/list]
