17 years agoSome ploblems about PCI core
I want to implement a 5v 32-bit PCI target in EP2C35 (with PCI compiler 8.0), but the computer just hung up after plug the card in motherboard. 1. The CyclonII devices support PCI. Does that mean ...
17 years ago1. I used QS3861 as level shifter, so I don't need to set PCI IO mode, it that right?
2. Can I use the constraints script (shipped with PCI compiler) to set the time constraint? btw, my pin allocation is different from the script, is that a problem? thx
