SMS's avatar
SMS
7 years ago
Soft LVDS IP core bitslip
I am using Max10 and included Soft LVDS IP core for data transmission and reception. For link training I sent 8'h0F. Now, the data at LVDS Rx slips every clock cycle.
I have tried to align it using the rx_data_align but that does not resolve the issue. LVDS IP was configured as:
General:
Power Supply Mode: Single Supply (for 10M16SAE144I7G)
Functional Mode: Rx
No. of channels: 1
SERDES factor: 8
PLL Settings:
Use external PLL (checked)
Receiver Settings:
Enable bitslip mode (checked)
Bitslip rollover value: 1
I have also tried to use internal PLL in which case the the bitslip occurs at random intervals. Now how can I fix this issue?
  • IDeyn's avatar
    IDeyn
    Hi SMS,
    It is a strange behaviour - in case align is stable you shouldn't get bitslip as it is on first figure.
    You could attach your project in order for community to check it.
    Ivan
  • SMS's avatar
    SMS
    Attached are two projects one for Tx and one for Rx. I am programming the DE10-Lite board (10MDAF484C7G) as Tx and a custom board (10M16SAE144I7G) as Rx.
    • IDeyn's avatar
      IDeyn
      Hi SMS,
      I quickly checked your project and I can say that you should begin with a creation of constraint file (sdc).
      You should start with create_clock command, FE create_clock -name {I_ADC_FCO} -period 20.000 -waveform { 0.000 10.000 } [get_ports {I_ADC_FCO}]
      After that and after successful timing analysis you should test if your design works.
      Ivan
