14 years agoSlow DDR2 reading
Hello, I'm implementing a FIFO using the DDR2 RAM in a 3C120 development board. Basically, I have two memory pointers, one for writing and one for reading, and I sequentially write 255 64-bit word...
14 years agoI will try to get some with signaltap. The memory controller is set to use 125MHz from a 50MHz clock, and the logic that manages the memory uses as its clock the sysclk output from the memory controller.
