10 years agoSingle Avalon-MM Master to Muliple Avalon-MM Slaves
I'm trying to connect multiple Avalon-MM slaves to a single Avalon-MM Master. I realize this essentially automatic using Qsys, if you're IP is defined as modules in Qsys. But all of my IP is alrea...
10 years agoI totally blame Altera. To assume all design can be forced into a proprietary system integration tool is a marketing decision. This Altera decision intentionally makes things difficult for engineers that aren't willing to work in the way prescribed by Altera marketing. By the way, I just used the equivalent AXI version of this in the Xilinx build environment. It was easy and worked great. Score one for Xilinx.
