10 years agoSingle Avalon-MM Master to Muliple Avalon-MM Slaves
I'm trying to connect multiple Avalon-MM slaves to a single Avalon-MM Master. I realize this essentially automatic using Qsys, if you're IP is defined as modules in Qsys. But all of my IP is alrea...
10 years agoI wouldn't blame Altera for this. You yourself said "I realize this essentially automatic using Qsys...". Your design choices and/or build methods in not using QSYS are making it harder for you than it needs to be.
