10 years agoSingle Avalon-MM Master to Muliple Avalon-MM Slaves
I'm trying to connect multiple Avalon-MM slaves to a single Avalon-MM Master. I realize this essentially automatic using Qsys, if you're IP is defined as modules in Qsys. But all of my IP is alrea...
10 years agoThanks Ted- I'll give it a try. Altera certainly does not make this simple task very easy (which is ironic since the whole point of qsys is to make things easier).
