10 years agoSingle Avalon-MM Master to Muliple Avalon-MM Slaves
I'm trying to connect multiple Avalon-MM slaves to a single Avalon-MM Master. I realize this essentially automatic using Qsys, if you're IP is defined as modules in Qsys. But all of my IP is alrea...
10 years agoEverything in Qsys including creating components, and connecting ports can be done in the command line if that's what you are worried about.
If you want to do this outside of Qsys, you can use multiplexers to create your own switching fabric. This is going to take longer than porting your design to QSYS if you have more than a few ports to connect.
