8 years agoSimulation stops before simtime
Any ideas why a simulation would stop early? When I run the simulation, scopes show the full simtime. However, after about 2-15% of the simtime, simulation will stop. If I keep the simtime the same a...
8 years agoWhen it stops can you run again?
Yes. I get the chime sound same as when simulation completes normally. Which simulator are you using? Running inside Simulink. Only simulating the DSP system. How do you run a simulation? Ctrl-T to build and run Thanks!
