18 years agoShould I expect critical warnings in DDR IP code?
I have a 7.2 design with the Altera DDR SDRAM controller megacore function. My design seems to work but I am getting the following critical warnings: Critical Warning: (Critical) Rule A102: Regi...
18 years agoFirst, Which DDR controller are you using? Is it the High Performance controller?
Do you have a license for this DDR SDRAM controller? Are you using any other Altera IP? Do you have a license for all of the IP in the design? If you don't have a license for every IP core in your design, then I believe that these messages may be coming from the OpenCore Plus H/W evaluation logic. In this case, these messages can be safely ignored. See AN320 on the Altera website which describes these warnings. If you have a license for all of the IP in your design, then you probably should not be getting these warnings, and the warnings may be pointing to a real problem. If you post the full text of the warning messages by expanding them, I might be able to tell you more.
