14 years agoShared IP - Stack Based Micro + assembler + testbench
I was trying to post this to shared IP forum, but i wont let me? Anyway I hope posting here is ok This is something I have been working for a little while - a simple 16 bit micro with an assembler, it is stack based so runs forth type code. The core is around 380LE in a 3C5F256C8 and runs at 87MHz running code. The top level is a micro+ram+timer+small pio - the micro responds to interrupts from the timer for demo purposes. Top level compiles to 606LE + 4M9k blocks - and can be cut down to run an a MAX V/ MAX II device probably EPM1270. Update : More work done on core, testbench etc - new attachmentNo RepliesBe the first to reply
